PETER KREKLOW Posted November 9, 2010 Share Posted November 9, 2010 For Sale $4,500. KOMET 12 KIT Highest power-to-light ratio 11,000 lumen Uses 6' HMI Par Lenses Included 65,000 Kelvin Uses less then 2.5 amps No projected heat Daylight balanced 25,000 LED life Fully submersible to 100' Durable machined aluminum 100-240 VAC, 50/60 Hz Power Supply with 3 way dimmer 25' Head Cable Film and video professionals designed the KOMET 12 with features they knew industry pros would appreciate. From the initial CAD designs all the way through production, they set their goals on building a high-powered, energy efficient, nearly indestructible LED fixture. They insisted that the KOMET 12 needed to work with standard lenses and light banks for complete beam control. They designed it to emit zero heat from the beam and very low heat from the fixture for fast breakdown and wrap to keep shoots moving. Using less then 2.5 amps while producing more light then a 1K tungsten or JOKER HMI . And finally, they made it completely submersible, able to withstand all types of weather conditions. List price $5,900.00 Check out www.KOMETLED.com for full details, also U-Tube under KOMET 12 The KOMET 12 kit for sale here is slightly used in perfect operating condition. There is slight staining from chemicals that were in the Koi pond while the KOMET 12 was submerged on FOX'S sound stage for the DOLLHOUSE TV series.. KOMET 12 KIT Includes KOMET 12 fixture w/25' Head cable International power supply 4-way Barn doors Frosted Fresnel lens Super Wide lens Wide lens Medium Flood lens Custom ATA case Contact me at grip@cox.net Link to comment Share on other sites More sharing options...
