Guest Steadicam Forum Posted February 9, 2011 Share Posted February 9, 2011 HereÂ’s the deal: My assistant (no names, to protect the guilty) dropped the transmitter and itÂ’s broken! It was in single channel mode at the time, ie just the tx and battery. IÂ’m sure it could be repaired or you can use it for spares. The second channel splitter handle and focus control are therefore fine, as is the receiver. ItÂ’d be ideal if you want to upgrade your single channel setup, or youÂ’re handy with fixing things. Parts list: Heden M26p motor, with 0.5(Canon), 0.6(Fuji) and 0.8 gears and Optex mounting bracket. 550GBP Heden M32p motor, with 0.5(Canon), 0.6(Fuji) and 0.8 gears and Optex mounting bracket. 650GBP Pantali tx splitter handle, with 2nd channel tx controller 3 channel receiver with 90deg aerial, inc power cable (HRS 4 pin to HRS 4 pin) Tx module (broken) with straight aerial 2x tx batteries and chargers (one cable modified to plug into fast charger via BP90 type plug) 1,500GBP Cables: Heden motor cables (5 pin) @ 60 GBP each 3x straight motor cables 2x coiled motor cables Camera run cables @ 50 GBP each 2x Arri (1 straight, 1 coiled) 1x Aaton (coiled) 1x PV 1x Millennium (coiled) 1x Arri III 1x Moviecam Receiver power cables @ 45 GBP each 1x Canon 4pin (UK spec 12v) (coiled) 1x Moviecam 1x tx power cable to Canon 4 pin (UK spec 12v) 40GBP 4x focus scale rings @ 5 GBP each All prices in GBP, + delivery costs from the UK. Dion Casey tel: +44(0)1460 30005 email: dion@dioncaseyfilms.co.uk Attached thumbnail(s) View or reply to the original post at SteadicamForum.com Link to comment Share on other sites More sharing options...
