Guest Sammi&torontofilm Posted February 19, 2005 Share Posted February 19, 2005 I am going to convert a EBM to S16,do i need convert the magazine too or the magazine can run s16 up without do anything,because i know the aaton LTR dont need any convertion on mag also could run s16 perfectly. Link to comment Share on other sites More sharing options...
Premium Member Chris Keth Posted February 19, 2005 Premium Member Share Posted February 19, 2005 I am going to convert a EBM to S16,do i need convert the magazine too or the magazine can run s16 up without do anything,because i know the aaton LTR dont need any convertion on mag also could run s16 perfectly. <{POST_SNAPBACK}> It shouldn't need any conversion, I believe. Link to comment Share on other sites More sharing options...
Rik Andino Posted February 20, 2005 Share Posted February 20, 2005 I know the aaton LTR dont need any convertion on mag also could run s16 perfectly. <{POST_SNAPBACK}> Some LTR mags might have to be modify to properly shoot S16 The thing is not about running the film through the mag The issue is more about scratching The mag might be scratching an area that wasn't use in R16 But in S16 will be use so you might have to adjust some gears... Basically I recommend shoot a test and then see... If you're getting a huge consistent scratch when projected You'll have to modify the magazine If not you're in the clear. Good Luck Link to comment Share on other sites More sharing options...
