m. tams Posted March 7, 2005 Share Posted March 7, 2005 Okay, so I've just dropped the eight cans or our freshly shot short at the lab to be processed and transfered. They offered the option of a 4:3 or 16:9 transfer. I chose 16:9 figuring that it'll look better, and assuming that this aspect ratio was standard for 16mm film. after some research I have discovered this is not the case. How much of our image will be lost if we transfer to 16:9 and will they 'stretch' the image to obtain this? I checked with my DP and she was framing for 4:3. Does the aspect ratio change happen at the processing stage, or at the transfer stage, because I have the possible option (i hope) of phoning the lab tomorrow to change my desired aspect ratio. any help would be appreciated. Link to comment Share on other sites More sharing options...
Premium Member David Cox Posted March 7, 2005 Premium Member Share Posted March 7, 2005 It happens at the transfer stage - so you can always change your mind :-) If your DOP framed for 4:3, then I suggest you transfer that unless you prefer the 16:9 (TV widescreen) shape, in which case you would likely be transferring the center 75%(ish) height of the frame, cropping the rest off. However, since your DOP didn't frame for this, you need to check that you aren't cutting off important bits of the frame - like heads etc Link to comment Share on other sites More sharing options...
m. tams Posted March 8, 2005 Author Share Posted March 8, 2005 It happens at the transfer stage - so you can always change your mind :-) If your DOP framed for 4:3, then I suggest you transfer that unless you prefer the 16:9 (TV widescreen) shape, in which case you would likely be transferring the center 75%(ish) height of the frame, cropping the rest off. However, since your DOP didn't frame for this, you need to check that you aren't cutting off important bits of the frame - like heads etc <{POST_SNAPBACK}> That's a lot David. That's exactly what I neede to know. Link to comment Share on other sites More sharing options...
