Justin Marx Posted April 10, 2005 Share Posted April 10, 2005 Got this meter (Minolta color meter II) from a friend, no instructions.. cant find any on the net either? Can anyone please give some some information on basic operations of taking a reading and or point me in the right direction of a manual.. Thank you very much!! - - Justin Link to comment Share on other sites More sharing options...
Premium Member Kevin Zanit Posted April 10, 2005 Premium Member Share Posted April 10, 2005 I have only played with my gaffers III, but I know they are similar in operation. The switches on the left side of the meter allow you to set the film type (Tungsten A or B, or daylight). The switch on the side of the flat disc receptor allows you to set the meter to high or low light settings. The button on the right side takes the reading. The mode button allows you to toggle through the various modes of the meter (CC, color temperature, etc.). There is also a switch on the right side that allows you to select the meter mode (corded flash, un-corded flash, or manual). Then you essentially just meter the light source as you would take an incident reading. Kevin Zanit Link to comment Share on other sites More sharing options...
Justin Marx Posted April 11, 2005 Author Share Posted April 11, 2005 Thank you! What does holding the film and up and down arrows at the same time do?? Also, what does the LB and CC and K buttons do? Thanks again! Link to comment Share on other sites More sharing options...
Premium Member Kevin Zanit Posted April 11, 2005 Premium Member Share Posted April 11, 2005 I don?t know about your first question. LB is for "Light balancing" filters and CC is for Color Compensating filters. K is for degrees Kelvin. Kevin Zanit Link to comment Share on other sites More sharing options...
