Premium Member John Pytlak RIP Posted April 19, 2005 Premium Member Share Posted April 19, 2005 Just introduced by Kodak at NAB 2005: http://www.kodak.com/US/plugins/acrobat/en...PCN040105_Q.pdf KODAK VISION2 HD Color Scan Film 7299 is a color negative camera film designed for use exclusively with theKODAK VISION2 HD System. Available in 16 mm widths only, it is a medium- to high-speed, extended latitude film with fine grain and excellent sharpness. Created specifically for television production, this film allows you to match the tone and color of many KODAK color negative film stocks when transferred with the KODAK VISION2 HD Digital Processor. This powerful digital processing combined with the film?s extended latitude makes it possible to shoot this film at a nominal exposure index of either 500 or 320. Further, even though this is a tungsten-balanced film, the KODAK VISION2 HD Digital Processor can compensate for color balance if the film is shot in daylight conditions without a Wratten 85 filter. The digital processing can also compensate for over and under exposures. The film is intended for scanning applications only and is not printable through traditional optical printing methods. The film must be transferred through the KODAK VISION2 HD Digital Processor hardware. KODAK will loan the KODAK VISION2 HD Digital Processor System to post production houses designated to Kodak by production companies using the KODAK VISION2 HD Color Scan Film 7299. Minimum volume purchases may be required to qualify for the use of a dedicated Digital Processor. Also, minimum system requirements must be met by the post house to operate the hardware. http://www.kodak.com/US/en/motion/campaign...005/index.jhtml http://www.kodak.com/US/en/motion/about/news/hdNAB.jhtml When I saw the Kodak HD Film System demos a few weeks ago, I was quite impressed with the various "looks" that could be achieved with this versatile film. Link to comment Share on other sites More sharing options...
Premium Member John Sprung Posted April 19, 2005 Premium Member Share Posted April 19, 2005 This sounds like it would be a good fit with FotoKem's 16mm to HD via 2k setup. Have you talked to them? -- J.S. Link to comment Share on other sites More sharing options...
Premium Member John Pytlak RIP Posted April 19, 2005 Author Premium Member Share Posted April 19, 2005 This sounds like it would be a good fit with FotoKem's 16mm to HD via 2k setup. Have you talked to them?-- J.S. <{POST_SNAPBACK}> I personally have not talked to them, but I'm sure some of our specialists based in Hollywood already have. :) Link to comment Share on other sites More sharing options...
