SteadicamForum Posted March 5, 2014 Share Posted March 5, 2014 I am selling my Steadicam Archer kit. This is a really well looked after setup with many modifications for HD use. The arm has had an X-upgrade with Tiffen USA and works beautifully. You won’t need to service or invest any extra money in to this kit for some time. Ready to go with many accessories. This is by far one of the best Steadicam Archer kits I’ve seen for sale (in my honest opinion). The reputable Optical Support and Tiffen International have carried out all modifications and services since new. ASKING PRICE: £11,500 (O.N.O.) SLED: Steadicam Archer Sled serviced regularly and exclusively by Optical Support London, all modifications carried out by Optical Support London. Modifications as follows: HD BNC connections fitted top and bottom to replace standard HD Lemo connectors feeding into the HD line within the post. SWIT 8.4 inch HD monitor with V-lock battery plate and fitted with custom monitor yoke. Top-stage nose replaced with Preston MDR mount plus adaptor that converts the MDR mount to a flat-mounting plate. A 3/8th captive screw included allowing you to mount alternative LCS receivers such as the Preston single-channel receiver also. Machined top-stage lever to allow superior clamping and a more solid locking mechanism than the standard lever offered. Tapered bayonet “Pro-style” bung fitted inside the locking mechanism of the folding lower section. This stiffens up the whole lower assembly of the sled and provides a more positive connection than standard and allows the two sections to actually be mated together as well as being clamped down by a threaded lock-ring. ARM: G50 with X-upgrade from Tiffen USA. This is basically a G50X arm now. Less than 1 year of use since upgrade. The upgrade included the replacement with all new mechanisms and bearings throughout the arm. Rain Cover included. VEST: Standard LX Vest, no modifications, good condition. ACCESSORIES / BRACKETS: Tiffen Dovetail Tiffen Universal Low-mode Bracket Tiffen low mode F-bracket Baer-Bel Dovetail with rail mounts front and back 1 x Baer Bell 15mm screw on rail for dovetail Baer-Bel Cat Griller bracket for Archer/Zephyr Facilitates speedy swaps between steadicam/sticks without removing Steadicam dovetail Various 3/8 inch Screws Tiffen Docking bracket with quick-release pin Basic tool kit including: T-handle Allen key for adjusting Vest Socket block and gimbal Allen key and t-handle screwdriver for attaching dovetails POWER: 4 x Pag L95 V-lock batteries 1 x IDX 2-way V-Lock Freelancer charger CABLES: 1 x 3-pin Lemo to 4-pin XLR Power Cable 1 x Red One Power Cable 1 x 2B to 1B Red Power Adaptor Cable 2 x BNC Cables CASES: 1 x Thermodyne case 1 x Pelican 1650 case (slight crack and chip but only cosmetic) Please note that the standard Steadicam docking bracket with the standard docking ring will be supplied. The pictures contain the Jerry Hill docking brackets with associated rings and an American Grip stand that is not included. Please contact me if you have any further queries. View or reply to the original post at SteadicamForum.com Link to comment Share on other sites More sharing options...
