Kenny N Suleimanagich Posted May 7, 2015 Posted May 7, 2015 Awesome, Alan. Can't wait for my Arri R/S to P-tap cable from you guys for my 416.
Alan Rencher Posted June 18, 2015 Author Posted June 18, 2015 New: Alexa-Mini EXT to R/S + Power Adapter http://mediablackout.net/product/alexa-mini-ext-to-rs-power-adapter/
Alan Rencher Posted July 23, 2015 Author Posted July 23, 2015 Media Blackout now has LBUS cables! LBUS cables supply power and bidirectional data to Arri & cmotion devices. http://mediablackout.net/product/lbus-cable/
Alan Rencher Posted July 31, 2015 Author Posted July 31, 2015 Preorder - BreakerBox Preorder the BreakerBox now for $125. the price will increase to $150 after Aug. 15th, 2015. Media Blackout is proud to unveil the new and improved BreakerBox! The BreakerBox is a black anodized, machined aluminum power distribution box. It’s minimal design is great for lightweight configurations, and it’s mounting holes allow the user to attach it directly to the side of any professional camera system or stabilizer. The BreakerBox Features: Genuine Lemo I/O Rectified genuine Anton/Bauer P-Tap (also called D-Tap) output 9mm on-center mounting holes that are compatible with Red and many other accessories Unregulated and polarity agnostic power pass-through Rugged and lightweight, black anodized, machined aluminum case More at the link: http://mediablackout.net/product/breakerbox/
Premium Member Phil Rhodes Posted July 31, 2015 Premium Member Posted July 31, 2015 I had no idea one could get paid for doing this sort of work! Hats off to you, sir.
Alan Rencher Posted August 23, 2015 Author Posted August 23, 2015 Now available - Amimon Connex Power Cables http://mediablackout.net/product/amimon-connex-power-cable/
Alan Rencher Posted September 24, 2015 Author Posted September 24, 2015 New! Canon C300 MkII Lemo Power Cable - The Media Blackout Canon C300 MkII Power Cable comes standard with high-quality, flexible rubber cord, coiled cable, or our exclusive MegaFlex cable (all made in USA). http://mediablackout...ii-power-cable/ Arri StarliteHD5 Interface Cable - The Arri Starlite HD5 Interface Cable provides the Transvideo StarliteHD5-Arri 5″ monitor-recorder with power and data from the Arri Amira or Alexa Mini. The Starlite connects to the Arri camera via its 5-pin Lemo, which supplies power to the monitor while allowing the user to control the camera via a touchscreen interface. The Alexa Mini’s 7-pin EXT port is also the camera’s only R/S port, but the Starlite offers no breakout for remotely starting the camera. That means the user has had to choose between R/S functionality and the use of the Starlite. Media Blackout has solved this problem by offering a Fischer 3-pin female dongle from the EXT port of the Alexa Mini. The inline Fischer jack allows the user to plug in any Alexa-compatible R/S plug to remotely start recording on the Alexa mini. Power-only cables are also available and come wired with a P-Tap, SafeTap, Fischer 3-pin, and Lemo 2-pin connector. http://mediablackout...nterface-cable/
Alan Rencher Posted October 15, 2015 Author Posted October 15, 2015 New: [stocked] 2-pin Lemo AC Adapter The Media Blackout 2-pin Lemo AC Adapter is a commercial grade 100-240V AC to 12V, 3.33A power supply. The wall wart is equipped with a non polarized NEMA-1 (North American) input plug and a standard 2-pin Lemo (0B.302) output plug. This product can be ordered in either pin-1 positive (Bartech, Letus, Redrock) or pin-1 negative (Teradek, Preston, Arri, Red) polarity. http://mediablackout...emo-ac-adapter/ Preston V+F Cables Media Blackout Cables for Preston V+F, also known as Preston Single Channel or Video Lens Control, are custom, high quality cables used for remote start and serial data. http://mediablackout...ston-vf-cables/
Alan Rencher Posted October 27, 2015 Author Posted October 27, 2015 New to the store - Heden Engineering remote start cables: http://mediablackout.net/product/heden-remote-start-cables/
Alan Rencher Posted November 4, 2015 Author Posted November 4, 2015 New: Alexa Mini Audio Cables Media Blackout’s Alexa Mini Audio Cables plug directly into the Alexa Mini’s 5-pin 00 Series Lemo jack on the camera body to allow direct connection to microphones, lav packs, and other audio equipment. All Media Blackout audio cables are properly shielded; don’t be fooled by other manufacturers’ “Flex” cables that are just bare hook-up wire in nylon sheathing. All styles of Media Blackout’s audio cable for the Alexa Mini are flexible enough to use with gimbal rigs. http://mediablackout...i-audio-cables/
Alan Rencher Posted February 12, 2016 Author Posted February 12, 2016 Check out the rundown of the I/O on the new Varicam LT on the Media Blackout Blog: http://mediablackout.net/blogs/news/92206214-what-you-will-need-for-your-new-panasonic-varicam-lt
Alan Rencher Posted March 16, 2016 Author Posted March 16, 2016 Media Blackout has created another first with the Rencher Industries BreakerBatt - A polarity-agnostic battery eliminator with Lemo power loop-out. Sony NPF is available now, and Canon LP-E6 is coming soon! Available at - https://mediablackout.net/products/breakerbatt
Alan Rencher Posted April 5, 2016 Author Posted April 5, 2016 NEW: Look out for this and other 3D printed products coming soon! 3-Stud Fiber Plate Media Blackout's 3-Stud Fiber Plate is part of our 3D product series. The plates are 3D printed in-house using high-quality nylon, reinforced with four layers of continuous strand carbon fiber. Fiber Plates attach to Gold Mount battery plates using our own T-Studs. Our T-Studs fit snugly in the plate, and do not wiggle like normal Gold Mount studs. These plates can be used to protect unused battery plates, which is especially useful for a downward facing battery plate on a Steadicam. They can also be used to create a quick release for accessories using velcro, epoxy, or mounting tape. 3-Stud Fiber Plates are strong, rigid, and extremely light at 1.6 ounces (45 grams), including hardware. When this item is marked as, "In Stock," they are ready for immediate shipment. Since these parts are 3D printed in-house, we can offer a multitude of customizations with fast turnaround. If you have a hole pattern you would like to include on a plate for a specific device, please contact us for a quote. All Media Blackout cable assemblies use genuine parts and high-quality cable. Cable assemblies are made to order at our office in Culver City, CA. If you need custom assemblies, please contact us. 0 Alan Rencher
Alan Rencher Posted April 12, 2016 Author Posted April 12, 2016 NEW: Look out for this and other 3D printed products coming soon! Hyperdeck Fiber Plate https://mediablackou...eck-fiber-plate Media Blackout's Hyperdeck Fiber Plate is part of our 3D product series. The plates are 3D printed in-house using high-quality nylon, reinforced with four layers of continuous strand carbon fiber. Fiber Plates attach to V-Mount plates using genuine IDX V-Locks or attach to Gold Mount battery plates using our own T-Studs. Our T-Studs fit snugly in the plate, and do not wiggle like normal Gold Mount studs. These plates are very light at 2.4 ounces (70 grams), including hardware, and they only add 0.1" (2.54mm) to the depth of the recorder. These plates are used to mount a Blackmagic Design Hyperdeck Shuttle to an unused battery plate, which is especially useful Steadicam operators. Hyperdeck Fiber Plates also have the added bonus of being able to attach a Hyperdeck Shuttle to standard V-Lock accessory mounts. Hyperdeck Fiber Plates have mounting holes for both T-Studs and V-Locks, but only come with either three T-Studs or one V-Lock. Additional mounting hardware can be purchased separately here or here. When this item is marked as, "In Stock," they are ready for immediate shipment. Since these parts are 3D printed in-house, we can offer a multitude of customizations with fast turnaround. If you have a hole pattern you would like to include on a plate for a specific device, please contact us for a quote.
Alan Rencher Posted June 8, 2016 Author Posted June 8, 2016 New: - Audio Breaker https://mediablackou...s/audio-breaker The Media Blackout Audio Breaker is a 2-channel breakout box that adapts devices with non-standard audio connectors to full size XLR connectors. The Audio Breaker features fully shielded audio cable, a milled aluminum enclosure, genuine Neutrik XLR connectors, and a universal 1/4 slot to attach directly to your rig or via 3rd party accessories. - Arri RS Breaker https://mediablackou...arri-rs-breaker The Media Blackout Arri RS Breaker is a 12V (unregulated), 24V (unregulated), and RS breakout for Arri or compatible cameras. The breakout box features four Lemo 2-pin (0B.302) connectors and four Fischer 3-pin (DG 102) connectors. The connectors are wired 1:1 to provide one input and three outputs for each connector type. The enclosure mounts to your rig via a male V-Lock dovetail (included). - 2-pin Lemo Polarity Tester https://mediablackou...polarity-tester One of the biggest causes of damage to equipment on set is using a 2-pin Lemo cable that is not wired for the device it's plugged into. That's why Media Blackout created the 2-pin Lemo Polarity Tester. To use the tester, plug the source-side of your 2-pin Lemo cable into any DC power source from 6-36V, and plug the device-side into the tester. The tester will show you if pin-1 is ground (GND) or positive (+VDC) by flashing one of two red LEDs. The tester also features a micro USB port for firmware updates. - Kraken 360 VR Power Distro https://mediablackou...-power-assembly The Media Blackout Kraken 360 VR Power Distro provides 14 regulated 5V, 3A USB ports, three unregulated P-Tap ports, and an integrated Anton/Bauer battery plate to power GoPro or other USB powered 360 virtual reality rigs. The distro can also be used to charge USB devices on set. This is especially good for sets that use a lot of GoPro cameras.
Alan Rencher Posted April 19, 2017 Author Posted April 19, 2017 We've updated our LogicBlock series to support new SmallHD 503 and 703 UltraBright monitors: https://mediablackout.net/products/logicblock
Alan Rencher Posted May 17, 2017 Author Posted May 17, 2017 (edited) New on the site: Voltage Meter - https://mediablackout.net/products/voltage-meter Media Blackout's Voltage Meter is a great way to keep an eye on your battery's voltage level. Just plug into any power source for an instant readout. Available with or without 2-pin Lemo pass-through. Edited May 17, 2017 by Alan Rencher
