SteadicamForum Posted May 11, 2015 Share Posted May 11, 2015 Steadicam Master Series rig. Master Series Sled with 3 recelled master series batteries and 5-channel charger. The sled is SD and currently has a Bon BPM-071s HD-SDI/HDMI daylight viewable monitor. The monitor was just serviced and contains many new interior components. The sled comes in the original case from Cinema Products and The Monitor comes in a Pelican 1400 case. Master/Ultra arm. The arm had a complete servicing and rebuild with new bearings at Tiffen about 18 months ago, which cost around $2500. Since then the arm has received some superficial surface corrosion due to being packed in a pelican case in high humidity. The damage is all-superficial. The arm is in perfect working order. The arm comes with bag. Master Series vest. The vest shows signs of wear but it still works great and is in decent condition. Also comes with a bag Chrosziel Genio follow focus system with Hayden motor and 2 batteries. 15lb weight plate - A weight plate I purchased from Janice Arthur. Ideal for flying small light weight cameras on the rig. There's also a pelican case of accessories including Extra Rods, Power Cables, Extra Screws etc. Price - $13,000 The Rig is located in NYC. I'm happy to deliver in the area or ship nation wide. Any questions or if you would like to see more pictures please let me know. Attached Images View or reply to the original post at SteadicamForum.com Link to comment Share on other sites More sharing options...
