TERADEK BOLT 1:1 KIT - TX/RX WIRELESS HD SDI VIDEO SYSTEM - USED - $1570.00
Always checked and had current firmware loaded by Teradek in Irvine, CA
Units are used but in PERFECT WORKING ORDER and paired by certified Teradek technician at time of sale - for no hassle perfect plug-and-play use by customer
contact direct for instant response: SALES@CINOFLEX.COM OR TIM@CINOFLEX.COM
Extra Receivers available if you'd like, please ask.
INCLUDES:
- (1) TX UNIT - SDI
- (1) RX UNIT - SDI
- (1) Pelican Case - custom made for Teradek Bolt
- (2) P-Tap PWR CABLES
- (1) AC Adapter Power UNIT
- (2) SDI Video Cables
- (1) Hardware kit as Originally Bought - various 1/4-20 and 3/8 hardware - not pictured but included
Product Highlights
  • Uncompressed Video & Audio Transmission
  • Supports Resolutions up to 1080p60
  • 300' Distance with 1ms Latency
  • Uses License-Free 5 GHz Frequency
  • 3G-SDI Input & Loop; 3G-SDI Output
  • Internal Antennas
Transmit uncompressed 1080p video wirelessly over 300 feet with the Teradek Bolt Pro-SDI Wireless Transmitter-Receiver Set. Included in this set are a Teradek Bolt transmitter and receiver both equipped with 3G-SDI ports. The units in this kit are compact and feature internal antennas so they can fit on your camera rig and in your video village, DIT cart, or director's monitor rig.
When transmitting uncompressed video, latencies of less than one millisecond can be achieved if no other video processing is necessary. Unnoticeable latency is important for directors and focus pullers to see the action at the same time the camera does.
The Teradek Bolt SDI Wireless Video Transmitter accepts SDI signals and can transmit them to a Bolt 300 Receiver up to 300 feet away in optimal line-of-sight situations. The Bolt system supports uncompressed video resolutions up to 1080p at 60 fps with 4:2:2 chroma subsampling. Because the Bolt system uses the 5 GHz wavelength, it does not require FCC licensing. Included with this transmitter is a shoe adapter to mount the unit to a camera's standard accessory shoe and a D-tap to LEMO power cable so you can power the unit with an onboard battery with a D-tap output.
The Teradek Bolt SDI Wireless Video Receiver accepts video transmissions from a Bolt 300 transmitter up to 300 feet away in optimal line-of-sight situations. The Bolt system supports uncompressed video resolutions up to 1080p at 60 fps with 4:2:2 chroma subsampling. Because the Bolt system uses the 5 GHz wavelength, it does not require FCC licensing. Aside from being able to output video via 3G-SDI, the USB 3.0 port can stream the uncompressed video directly to a PC for recording with the GRAB Engine. Included with this transmitter is a 1/4"-20 thumb screw to mount the unit to a video rig and a 1/2"-20 adapter to secure the unit to a small light stand.
Price lowered --------------------------- NOW: $1075.00 for the kit
After some research I've decided to beat or meet any equivalent pricing.
  • 1 month later...
sorry
correcting previous post, the price is $1275 NOT $1075.
New Price $1275.00
Thank you and sorry for any misrepresentations
