Andrew Greenan Posted April 7, 2004 Share Posted April 7, 2004 HI. i'm shooting an exterior night rain scene on super16 in a week's time. i'm using Tungsten/ incandescants for their muddy quality and going for High contrast, with a strong backlight and key. i will probably only get a stop of 4 from the distance and the lights i'm using, but hope for 5.6. i wonder what the best stock to use might be: Do you think i'll get enough stop on the 7277 320T, as it is supposed to have a wide latitude? If i go for faster, 500T, which might suit me better Vision 7279, or Vision 2, 7218? i'm going for a clean look, muddied from the lighting and rain. Any thoughts much appreciated. Andrew Link to comment Share on other sites More sharing options...
Premium Member John Pytlak RIP Posted April 7, 2004 Premium Member Share Posted April 7, 2004 I'd go for the 7218. B) Most people think this film is amazing. Link to comment Share on other sites More sharing options...
Guest davidrmorrison Posted April 7, 2004 Share Posted April 7, 2004 I agree with John. The 7218 is an excellent choice. It's fine grain and natural color reproduction make it versatel in all sorts of lighting setups. I use it myself on most projects that I shoot. But, if you want to shoot at a 5.6, I don't think you'll get it with the lights you mentioned. Try pushing the film 1 stop but rate it at 800 asa. You'll then be at a 2.8 / 4, or close to that. I'm not sure about the added grain in 16mm but I don't think it will be that drastic. in my experience, the 5218 holds the highlights more than the shadows. At about 4 to 5 stops above the key and 3 stops below you can render detail. The 7218 may have more grain in the shadows than the 5218. To be safe I would open up another 1/2 stop. Good Luck! David Morrison Link to comment Share on other sites More sharing options...
Andrew Greenan Posted April 9, 2004 Author Share Posted April 9, 2004 Thank you, i think i'll go for it. 7218 i'll let you know how it turns out. Andrew Link to comment Share on other sites More sharing options...
