The LS 600x Pro boasts an expanded bi-color range fo 2700K~6500K while still being able maintain an impressive output. Equipped with its native Hyper-Reflector, the 600x Pro can output 5,610 lux at 3 meters (10 feet). With the F10 Fresnel modifier, the combination can reach an illuminance of 18,5100 lux at 3 meters in 15° spot.
https://www.aputure.com/products/ls-600x-pro/
Similar to the LS 300x, the 600x Pro utilizes Aputure-designed color-blending optics that combines its bi-color chipset into a single cohesive light source, allowing it to be used with optical lens modifiers such as the F10 Fresnel and Spotlight Mount.
Every aspect of the LS 600x Pro was designed with professionals in mind, with incredible output, a weather-resistant construction, a wide variety of power options, and professional level lighting controls, including Sidus Link, Art-net, and Wireless DMX. This is the LS 600d Pro, and it’s ready to blow away traditional lighting.
The LS 600x Pro joins the professional Light Storm series featuring enhanced, stepless dimming, as well as light control in 0.1% increments, ensuring that you get the exact amount of light that you need.
The LS 600x Pro features two output modes: Max Output and Constant Output mode. In Constant Output mode, the luminance level remains uniform while changing the CCT output. Max Output mode will always maximize the output for the chosen CCT and dimming level.
In addition to its responsive on-board controls, 2.4G remote, DMX512 5-Pin XLR In and Out, and Sidus Link® app compatibility, the LS 600x Pro is the first-ever Aputure light to simultaneously support sACN, ArtNet, and LumenRadio CRMX compatibility.
Sidus Mesh integration allows users to control the 600x Pro from nearly any smartphone or tablet with the Sidus Link mobile app up to 400 meters away with the addition of other fixtures, including the Aputure LS C300d II, LS 300x, Accent B7c, MC, and Nova P300c.
With exceptional color accuracy measurements of CRI&TLCI≥96, CQS≥95, and SSI scores of (D56): 74, (Tungsten): 85, the 600x Pro provides consistently accurate light quality for all filmmakers, upholding a color temperature standard of 2700K~6500K.
Like the LS 600d Pro, when plugged into AC power, the LS 600x Pro doubles as a high-intensity bi-color fixture and a supplementary charger for V-Mount & Gold Mount batteries, making it a useful addition to any filmmaker's toolkit.
The LS 600x Pro can utilize 9 different built-in light effects: "Paparazzi", "Fireworks", "Lightning", "Faulty Bulb", "TV", "Pulsing", "Strobe", "Explosion", & "Fire". The 600x Pro is also compatible with the SidusPro FX ecosystem.
Continuing Aputure’s philosophy of modular lighting control, the LS 600x Pro’s Bowens Mount makes it compatible with Aputure’s lighting modifiers like the F10 Fresnel, Light Dome II, Spotlight Mount, and Lantern 90, but also third-party accessories from companies like DoPchoice and Chimera Lighting.
The LS 600x Pro features a detailed LCD screen interface that, including a revamped professional UI that displays important information in an intuitive way, including easy-to-read intensity and color information.
CCT 2700K~6500K
Power Consumption ≤720W
Operating Current 8A
Operating Voltage (Power Supply) 100V~240V, 50Hz/60Hz
Operating Voltage (Battery): V-Mount / Gold Mount (Two Batteries) Half Output 12.5V-16.8V (14.4/15A) 22V-33.6V (26V/8.5A, 28.8V/7.5A)
Operating Voltage (Battery): Voltage V-Mount / Gold Mount (Two Batteries) Full Output 22V-33.6V (26V/18A, 28.8V/16A)
Operating Voltage (3-Pin XLR [48V DC]) 48V/15A
Battery Charging (Voltage) 16.8V/29.4V
Battery Charging (Amperage) 3A
Control Methods On-board, 2.4GHz, Sidus Link (Sidus MeshTM), 5-Pin DMX512, Art-net, LumenRadio
Wireless Operating Range (2.4GHz) ≤100m
Wireless Operating Range (Bluetooth) ≤80m
Wireless Operating Range (LumenRadio) ≤100m
Screen Type Adaptive Brightness LCD
Firmware Upgradeable USB (FAT16/FAT32), Sidus Link OTA
Cooling Method Active Cooling
Weatherproofing Dust & Water Resistant
Cable Type: Max Head Cable Length 7.5m
Cable Type: Power Cable Neutrik® powerCON TRUE1 TOP AC Power Cable (6m)
Accessory Mount Bowens Mount
Mounting 16mm / 28mm | 5/8in (Baby Pin) / 1.125in (Junior Pin)
