Kit Mackenzie Posted November 23, 2022 Posted November 23, 2022 For Sale: A Sachtler Studio II Heavy Duty tripod head and legs system with hard case Photos here Tripod head: Sachtler Studio II / Arri 150M Fluid Head 150mm bowl fitting Snap plate (1/4” and 3/8” screws) seated in a top sliding plate (removable) on a 17cm dovetail - giving 10cm of adjustment range when using snap plate 8 Pan tension settings (0>7) 8 Tilt tension settings (0>7) 8 levels of counter balance via 3 individually selectable and mixable levels +90º to -60º tilt range Pan and tilt locks working great 2 section pan handle with mounting rosettes on either side of the head Load capacity: 50kg Legs and mid level spreader: 3 Stage legs with 150mm bowl fitting and weight hook Removable mid level adjustable 2 section spreader with 4 angle positions 3 Removable rubber feet, legs are double spiked when rubber feet removed Spare rubber foot included. Hard Plastic Tripod Carrying Tube: Ronford Baker Brand Side carrying handle built into case Top opening and buckle Very strong 108cm tall with lid, 27cm wide Overall the system shows wear and has marks in places but is all in very good operational condition - this is a heavy duty head and a solid system with plenty of life left in it. I’m open to offers and also a possible part exchange for a less heavy duty setup. Based in London (SW9), willing to ship if needs be. Weights Tripod head: 7kg Legs: 5.4kg Tube: 4.9kg Total: 17.3kg Heights (measured from top of snap plate to include head height of 18cm) Lowest operational height: 77cm (spreader at widest position, could be lower if removed and working outdoors) Tallest operational height: 175cm (spreader at narrowest position and all leg sections extended) Price: £4000 ONO
