Matias Nicolas
pre-production set up
Hi! I wanna know which digital tool, do you use or you know dp's use in big budget feature films or big comercials to design the lighting of a studio or big set. For ej:  (you can correct me!!) in the AC mag sometimes you see that in some movies the have a loke an architecture plan in some type of scale, with all the ligths, and measures of the set,   for big planning studios shots. I been watching also a plug in called the "cine designer" which is a plug in for cinema 4D from Cinematograhpy Database, where you can also plan your shot in 3D. Which I was amazed. Please, let me know every thing you know! thanks..
Share this post
Link to post
I use "Shot Designer" for overheads and "Shot Lister" for the shot list.  "Sun Surveyor" to double check where the sun will be through out the day.  "Cine Designer" is a neat tool but I have yet to be able to incorporate it into my usual workflow.  If I'm fortunate enough to have floor plans or some other architecture plans given to me in advance I use them as the base layer in "Shot Designer".
Share this post
Link to post
ok! Im cheking it right now.. thanks!
Share this post
Link to post
Guest
Reply to this topic...
  Only 75 emoji are allowed.
  • Just Cinema Gear
    G-Force Grips
    The Original Slider
    FJS International
    Cinematography Books and Gear
