Henry Cline
Need to scale BNC 1080p to HDMI 720p
I have a pair of VR goggles that only accept 720p that I would. like to use with an Arri Mini. I have tried every converter and scaler I can find, the only setup that works so far is using a Bolt 300. I am hoping there is a smaller, less expensive option. Everything on the consumer market cannot deal with a signal coming from a pro camera. Everything needs to be small and light and easy.
A assume a Decimator MD-HX HDMI and SDI Cross Converter with Scaling & Frame Rate Conversion will work, but it is $295 and powering it via battery might be an issue.
I tried every box I could find on Amazon and none of them worked. Any thoughts or ideas appreciated
Henry
Share this post
Link to post
Guest
Reply to this topic...
  Only 75 emoji are allowed.
  • Wooden Camera
    FJS International
    G-Force Grips
    Just Cinema Gear
