Aloha 🙂
Has anyone on here ever used the Optex Super Cine 4mm on a Bolex H16 SBM Super 16?
The only footage I've seen of the lens online seems to be shot on an Aaton or an Arriflex, but I imagine in terms of field of view and coverage the lens would look the same on a Bolex even if it requires a PL to Bolex Bayonet Adapter?
I would appreciate any insight or reassurance.  My technical expertise is more on the post side of things but I'm starting to play with film again and if i'm incorrect I don't want to find out the hard way after having the gear shipped to me.
Thanks so much!
Erik
I don't have the 4mm but I do have the Optex 5.5 and I've used it on my Bolex .
There's no reason to think the 4mm would be any different.
It'll cover super 16,but since It's not a RX lens so you could get aberrations from the prism if you open wider than T 3.5ish.
Aloha Phillip.
Thanks for your reply.  I'm assuming that means you used the Optex 5.5 on non-bolex 16mm cameras and everything was the same in terms of coverage/field of view? That's what I assumed.
Good to know in terms of the aperture as well. Thanks so much for sharing that.
Have a nice day.
I've used my Optex 5.5 on my Bolex Super 16mm SBM using a PL mount adaper.  It worked just fine.  The 4mm should also be fine since it's also designed for Super 16.
