Site Sponsor Rick Anderson Posted August 19, 2024 Site Sponsor Posted August 19, 2024 $93,000.00 CAMERA KIT ARRI ALEXA 35 Production Set (19mm Studio) (1) ALEXA 35 Camera Body K1.0039373 – 631 HOURS as of 8/14/24 (1) ALEXA 35 Cine License 10.0043678 (1) ARRI LPL Mount (LBUS) K2.0018983 (1) ARRI PL-to-LPL Adapter K2.0016936 (1) Balance Utility Dovetail BUD-1 K2.0034180 (1) B-Mount Battery Adapter K2.0023751 (1) Multi Viewfinder MVF-2 K2.0020916 (2) Cable VF Right Angle (0.5m/1.5ft) K2.0042857 (1) Camera Power Cable Straight 2m/6.6in KC-50 K2.75007.0 (1) Power Distribution Module PDM-1 K2.0024101 (1) Production Support Set – Top KK.0041533 Low Mode Support LMS-4 Top Extension Bracket TEB-1 Center Camera Handle CCH-5 Square Accessory Sleeve SAS-1 Viewfinder Mounting Bracket VMB-5 (1) Production Support Set – Side KK.0041534 Camera Side Bracket CSB-1R Camera Side Bracket CSB-1L Camera Side Bracket CSB-1R Extension Rod Mounting Bracket RMB-7 Articulating Mounting Plate AMP-1 KK.0041535 1x Production Support Set – Bottom (19mm) Compact Bridge Plate CBP-5 (19mm) Bottom Plate 300mm / 12″ MEDIA Codex HS Media Bundle (3) 2TB Compact Codex Drives (1) Thunderbolt 3 Compact Drive Reader (1) TB3 Cable (1) Power Supply ACCESSORIES ARRI Power Supply Light 24v ARRI 19mm Support Rods – 17.3″ (440mm) Core SWX Direct Connect Helix Battery Plate for ARRI ALEXA 35 (Gold Mount) Wooden Camera A-Box (ALEXA MINI LF/35) Innerspace Case for ARRI Alexa 35 w/ Pull Handle & Wheels ALEXA 35 RONIN R2 MOUNTING HARDWARE (2) CineMilled Stage 1 Upper Tilt Arm Extension (1) CineMilled Universal Mount for mounting R2 to dolly/jib (1) CineMilled Mitchell thread w/ castle nut (1) CineMilled Castle Wrench (1) ARRI Adjustable Top Plate (1) Ignite Digi Adapter plate (1) ARRI SAM-9 quick release bottom plate
