I was using a borrowed DVX100a the other day ran into a bit of a focussing issue.
I was shooting a head-n-shoulders interview in low light, wide open (f1.7), manual focus. Camera locked off on sticks. No ND. Probably about 7 or 8 feet from the subject.
I'd zoom in all the way and set the focus, and then zoom out to the middle of the zoom to a good head and shoulders shot. Things looked sharp in the LCD, but when reviewing the footage later on a larger monitor, the wider shot was a little soft, and the background behind the subject was sharp.
Back in the office, I setup the DVX100a (f1.7) on sticks and pointed it at a large bookcase on the opposite wall. I set the Auto Focus to ON and watched the "focus numbers" in the LCD fluctuate consistently between 55 (wide-to-medium focal length) and 68 (zoomed in).
Is this a back focus problem?
I believe this technique does not work for this camera. Have you seen the DVX Focus Charts?
Tim, what do you mean by low light? Auto focus can be a problem
in low light! Was the area behind the subject lighter than the subject?
Was your subject maybe backlighted? Something threw your focus
off! The DX100A I would think would perform flawlessly except for the
known limitations of auto focus. I'm not sure I understand your situation.
I wonder if subject was backlit and you did not compensate with DX100A
"backlight" control(compensation). I wonder if you were shooting at known
limitations. With PD-170 I would have shot in manual mode(set my zoom)
manually. If Iwould have seen backlit situation I would have pressed the
"backlight" compensation control. I wonder if there was more light behind
your subject thus subject slightly out of focus,with more light behind sub-
subject rear of subject would focus sharply. I'm not sure if I'm interpeting
your situation accurately. I find that I have to be very careful in low light
during weddings in churches and when I shoot at the Pennsylvania State
Capitol in low light. Why did'nt you move your subject to more light for the
interview(I'm not trying to be a smart ---) always analyze your shoots,
shooting. I wonder maybe if you were shooting at limitations of auto focus
and also may have needed exposure compensation for backlight. My girl-
friend Stephanie, shoots with DX100A(loves it!). I'll pick her brain about you're
situation and get back to you here. Maybe something with f 1.7 too!
Thanks for the focus chart info. It has been dead on. I?m still pretty good at guessing distances and knowing 66% on the focus chart equals 6? etc.. Makes it pretty easy. It?s a shame the Auto focus is so slow on the camera.
Bob
  • 1 month later...
Here's the chart info, which I saved from the linked webpage before it was taken down:
Measured from the accessory shoe / light mount.
50% 3?10"
51% 3?11"
52% 4?
53% 4?1"
54% 4?2.5"
55% 4?4"
56% 4?5"
57% 4?6.5"
58% 4?8"
59% 4?10"
60% 4?11.5"
61% 5?
62% 5?2"
63% 5?4"
64% 5?6"
65% 5?9.5 ?
66% 6?
67% 6?3"
68% 6?6"
69% 6?9"
70% 7?
71% 7?4"
72% 7?8"
73% 8?
74% 8?6"
75% 8?12"
76% 9?6"
77% 10?
78% 10?8"
79% 11?6"
80% 12?4"
81% 13?4"
82% 14?7"
83% 16?
84% 17?9"
85% 19?11"
86% 22?9"
87% 26?6"
88% 31?10"
89% 39?9"
90% 52?11"
91% 79?5"
92% 160?8"
93% Infinity
