Jason Maeda Posted August 27, 2004 Share Posted August 27, 2004 can anyone refer me to a film that used a bleach bypass process for both the neg and the print? also, when a film is bleach-bypassed during the print stage only, then the video version must have the look re-created by the colorist. are there any tell-tale signs that let you know this was the case? jk :ph34r: Link to comment Share on other sites More sharing options...
Premium Member David Mullen ASC Posted August 27, 2004 Premium Member Share Posted August 27, 2004 I did both bleach-bypass to the print AND the neg for a short film but usually that's much too high-con for feature films. Most films, if they use bleach-bypass at all, would either do it to the neg or the print -- but not both. The primary difference between creating the bleach-bypass look in the telecine transfer versus using it on the print is the visible graininess, but since graininess is hard to see on a video monitor anyway, most people do not miss the grain. Janusz Kaminski has lately been using a low-con print instead of an IP for some of his transfers (like for AI and Minority Report) to keep some of the grittiness -- IP's tend to be much smoother and lower contrast. The loss of shadow detail from using a low-con print, even if normally processed, compared to using an IP, probably helps him create that skip-bleach look in the telecine a little easier because he isn't fighting having too much shadow detail to try and throw away. Link to comment Share on other sites More sharing options...
Jason Maeda Posted August 27, 2004 Author Share Posted August 27, 2004 thanks david, appreciated as always. jk :ph34r: Link to comment Share on other sites More sharing options...
Premium Member John Pytlak RIP Posted August 27, 2004 Premium Member Share Posted August 27, 2004 Kodak VISION Color Teleprint Film: http://www.kodak.com/US/en/motion/products...1.4.8.4.3&lc=en Link to comment Share on other sites More sharing options...
