Zeiss Primes for 35mm
Nathan Milford
I've got a set of very nicely maintained Zeiss Primes for 35mm. So well maintained that I cannot easily guess the age.
I know the revision of the 16mm primes (mk I, II, III etc..) but what are the distingusing charactaristics of thier 35 mm cousins.
I think they are Mk II's as they have a non rotating front...
Any guidence would be swell.....
Link to comment
The first sign would be whether they are T1.3 or T1.4. The first generation was T1.4. If I recall they always had non-rotating fronts. The first two generations would dramatically lose resolution when stopped down past T8 or T11. The Mk3 lenses were much better on this.
Link to comment
  • 4 weeks later...
Mr Gross is correct the t 1.4 is a mk I the t 1.3 is mk II the difference between II and III is not the glass but the barrel markings and color of same. The III's are a little easier to use for an AC slightly wider markings.
GWPB
Link to comment
Ask a lens tech there is no discernable diff. between MK II and III except for the barrel design
Link to comment
