brian hendry Posted September 28, 2004 Share Posted September 28, 2004 so i read this forum weekly, but have never posted. im about to shoot on a SR3, and i have access to a SR2 head. just wondering if it will fit on an SR3? or do i need to rent a head as well? ....i have a base plate for the SR3. and a tripod that fits the SR2. thanks. brian johnston Link to comment Share on other sites More sharing options...
Mitch Gross Posted September 28, 2004 Share Posted September 28, 2004 I assume you're talking about a tripod head. Both cameras use a standard 3/8"x16 screw for mounting so that's no issue. The SR-3 is a little heavier that the SR-2, so this might make a difference. But generally if it works okay on the SR-2 then it will also be fine for the SR-3. Link to comment Share on other sites More sharing options...
brian hendry Posted September 29, 2004 Author Share Posted September 29, 2004 I assume you're talking about a tripod head. Both cameras use a standard 3/8"x16 screw for mounting so that's no issue. The SR-3 is a little heavier that the SR-2, so this might make a difference. But generally if it works okay on the SR-2 then it will also be fine for the SR-3. <{POST_SNAPBACK}> thanks a bunch. Link to comment Share on other sites More sharing options...
