Alberto Larios-Saavedra Posted November 23, 2004 Share Posted November 23, 2004 Does anyone know what the recording "speed" of the older Sony Mini Disc MZ-R50 (and by speed I mean in terms of fps)? Might shoot some 16mm, telecine, then edit at a computer on Xpress Pro, so how do I sync up audio and video? Thanks, Al Link to comment Share on other sites More sharing options...
Sam Wells Posted November 24, 2004 Share Posted November 24, 2004 This Q should go on the Sound forum, but the MD recorder doesn't run at any kind of "fps"; for our puroses digital audio recorders run at their sampling rate.. Sync with slate / clapper is the easy answer. -Sam Link to comment Share on other sites More sharing options...
Guest Daniel J. Ashley-Smith Posted November 24, 2004 Share Posted November 24, 2004 (edited) Like Mr. Wells said it's recorded at a sampling rate. Typically there are 44.1khz (44,100 cycles) a second, sometimes 48khz. Although with DVD's they are now venturing into 96khz recording. So if your running 25fps, your hearing 1764 cycles a frame. (With 44.1khz) Trouble with slow motion scenes is that the audio and video is almost doubled, so you will lose huge amounts of sound quality. I believe the highest possible recording is 192khz. Although I've never actually seen any effects processors run at that rate. So 96khz is the next step. ------------------------------------------- The main things to look out for in a recorder: Make sure it's DIGITAL for a start. No less than 44.1khz recording. No less that 16bit depth. An output and input that will comply with the equipment your using. (i.e. no good having a microphone with an XLR jack when the recorder uses 1/4 inch, you can get converters but they are un-reliable) -------------------------------------------- I have a funny recording set-up. I use my BOSS GT-6 guitar effects processor to model the sound, and make use of the 96khz 24bit S/PDIF connection which runs to a card on my computer. ------------------------ But yeh the best place for this question is the sound forums. Edited November 24, 2004 by Daniel J. Ashley-Smith Link to comment Share on other sites More sharing options...
