Ype Poortinga Posted December 8, 2004 Share Posted December 8, 2004 Hey, I'm thinking about using a anamorphic lens with a mini35 set on a dvx100 for an upcoming project. Does anyone know a way to unsqueeze the image on the set? Using the 16:9 button on the monitor will of course help a bit, but is not a total solution Link to comment Share on other sites More sharing options...
Guest asiapacpro Posted December 11, 2004 Share Posted December 11, 2004 To display the "unsqueezed" image correctly you need to digitally modify the picture being fed to a normal monitor. There are some models that have this feature built in, or you can purchase a converter. Look here: www.transvideointl.com/pages/ english/products/anamorphic.htm These puppies are expensive, Around $1300, and although very close, are not 100% accurate. If you are going to do this on a long term basis, I'd suggest a properly calibrated monitor. Link to comment Share on other sites More sharing options...
