Michael Jones Posted December 29, 2004 Share Posted December 29, 2004 I have a question regarding audio on the camera... When using the front mic (mounted on camera) I am recording to channels 1 and 2 even though it is a mono signal. Correct? When I am using the Azden wireless mic (BTW I did not end up getting the in-slot receiver model) I am plugging it into channel 1(xlr) in the back of the camera. I am only getting the one signal for that one channel. Is there a way to get that one channel (1 xlr) to record on both channel 1 and 2 like the front mic does mounted on the camera? I discovered that plugging the Azden into the front xlr jack I get both channels. In this case, I have disabled the front Mic and will only record wireless. I guess this leads to another question... when recording w/ wireless mic, do I want to record audio from the camera mic as well? Simultaneously? Any thoughts would help... Thanks, -mj Link to comment Share on other sites More sharing options...
Premium Member Phil Rhodes Posted December 29, 2004 Premium Member Share Posted December 29, 2004 Hi, I'm not specifically familiar with the SDX-900, but on every other broadcast camera I've ever used you can switch the audio sources and levels to and from more or less anywhere. Phil Link to comment Share on other sites More sharing options...
Ken Zukin Posted December 30, 2004 Share Posted December 30, 2004 Hi Michael, That's normal for your wireless receiver to be switched into the one audio channel. Usually, at least with a 2 channel Betacam, it was pretty standard to have the wireless switched into one channel, and the on-camera mic routed (as a back-up) to the other channel. If you want to send the signal from your wireless into both channels, you can buy/make a "Y" XLR cable that will do that for you. Some audio techs like to have that kind of redundancy, and they will run one of the audio channels about 20% below the normal level. This helps prevent over-driving the one channel if the person being interviewed raises his/her voice unexpectedly. Enjoy your SDX900. Ken Z. Link to comment Share on other sites More sharing options...
Michael Jones Posted December 30, 2004 Author Share Posted December 30, 2004 Thanks Ken for the great response. I am assuming that the best "rule of thumb" is to keep the front camera mic on at least one channel when using a wireless. Link to comment Share on other sites More sharing options...
Premium Member John Ealer Posted January 8, 2005 Premium Member Share Posted January 8, 2005 Keep in mind that the SDX-900 can record 4 channels of audio, and that you can record the front mic into channel 3 or 4 (with auto gain control) and record your wireless onto channel 1 and 2, should you wish. That way you get maximum diversity and protection. J Link to comment Share on other sites More sharing options...
