Etienne Cohet Posted January 27, 2005 Share Posted January 27, 2005 All details I remember : - A digital (big) mono-ccd camera - For Cinema - 35mm Lenses Mount ! I guess it was possible to get 2(or 4)k datas, hd, pal, ntsc, and we come to the point I think I'm dreaming ... Does anyone know that cam or something ? Thanks, Etienne. Link to comment Share on other sites More sharing options...
Premium Member David Mullen ASC Posted January 27, 2005 Premium Member Share Posted January 27, 2005 The Panavision Genesis, Arri D20, and Dalsa Origin all have single 35mm sensors, although the Dalsa is the only one claiming 4K resolution for the final image; the other two are recorded at HD resolution. Link to comment Share on other sites More sharing options...
Michael Most Posted January 27, 2005 Share Posted January 27, 2005 The Panavision Genesis, Arri D20, and Dalsa Origin all have single 35mm sensors, although the Dalsa is the only one claiming 4K resolution for the final image; the other two are recorded at HD resolution. It should also be pointed out, however, that none of the aforementioned devices (with the possible exception of the Dalsa, I'm not sure about that one...) are actually available yet. Neither is the Kinetta, which would fall under the same category if it were available. So the bottom line answer to the original question is: all PR aside, there aren't any single 35mm sensor electronic motion picture cameras. At least at the moment. Link to comment Share on other sites More sharing options...
Etienne Cohet Posted January 29, 2005 Author Share Posted January 29, 2005 (edited) Thank you, with the names I can check sites. As usual, answers when we need. Etienne. PS : To all registered readers, vote Yes to keep the archives online. :ph34r: Edited January 29, 2005 by Etienne Cohet Link to comment Share on other sites More sharing options...
