Guest Sprocket14 Posted February 15, 2005 Share Posted February 15, 2005 hello all, My situation is I have an actor crouching on the floor in the back of the car hiding from the driver. It's a comedy shot on betaSP. Will daylight be enough? I'm thinking just use careful bouncing. But I'd like to hear other suggestions. Link to comment Share on other sites More sharing options...
Jon Rosenbloom Posted February 16, 2005 Share Posted February 16, 2005 ND gels for the windows, tape for the gel. Tape, or use some safety pins, bleached muslin to the cieling and bounce a pocket par into the muslin. Link to comment Share on other sites More sharing options...
Guest Sprocket14 Posted February 16, 2005 Share Posted February 16, 2005 ND gels for the windows, tape for the gel. Tape, or use some safety pins, bleached muslin to the cieling and bounce a pocket par into the muslin. <{POST_SNAPBACK}> Sorry but I'm still new to this. What is a bleach muslin and a pocket par? Link to comment Share on other sites More sharing options...
Rik Andino Posted February 16, 2005 Share Posted February 16, 2005 A Pocket Par is a type of light It is a small portable HMI light (daylight balanced) It can be powered by your car battery--so it's perfect for shooting CAR--INT. A Bleached Muslin is a heavy white cotton cloth You can use it to bounce light, & it's also pretty affordable ($5 bucks a yard). However I recommend a simpler method Don't gel the windows allow as much light possible Get a Pocket Par Or better yet I prefer MINIFLOS (portable KINOFLOS) And use them to light the INT. It's very important: Try to get a good balance between the EXT. and the INT. I believe having the EXT. 2 stops higher than the INT. is good. (at least for film) I would shoot a test to see how that would look on DigiBeta And also have a well calibrated monitor on set--it'll help. Good Luck Link to comment Share on other sites More sharing options...
Guest Sprocket14 Posted February 18, 2005 Share Posted February 18, 2005 Awsome, thanx for the help guys. Link to comment Share on other sites More sharing options...
Rodrigo Llano Posted February 20, 2005 Share Posted February 20, 2005 A cheep solution when you have a low budget is a cars ND. You could buy it in a car supply store and you will have an emergency solution. Obvously is less clear than the profesional ND , but work well., specially if you shoot on video , because of the resolution Link to comment Share on other sites More sharing options...
