Dave Plake Posted February 23, 2005 Share Posted February 23, 2005 could someone explain how to change the shutter degree on an arri 35-III? i know how to change the 435, think I know the III but need help as not to break it! Link to comment Share on other sites More sharing options...
Kim Sargenius Posted February 24, 2005 Share Posted February 24, 2005 There is a 2mm Hex key nut near the centre of the mirror -- turn gently until the shutter appears from behind the mirror, it has markings at (from memory) 172.5, 90, 45. HTH Kim Sargenius cinematographer sydney Link to comment Share on other sites More sharing options...
Guest Bruce Frye Posted February 25, 2005 Share Posted February 25, 2005 Hello, not all Arri IIIs had variable shutters, If yours does, use a 2mm allen wrench to adjust it by rotation of the screw, (on the shutter hub) but you must press down gently on the screw to disengage it, once you have moved the shutter to the desired angle (settings engraved on the variable wing) allow the screw to raise back up or the wing will not be locked in place. Bruce Link to comment Share on other sites More sharing options...
