Here is a strange photo i found on a web site
of a distributor of "Synchro film and video" services (Germany)
Here is the picture:
What could this be? Bright green film? I can't think of anything using
green film,even dye transfer process uses substractive color dyes right?
What could this be?
And what kind of a scanner or printer is this:
Is it a celco printer?
The green stuff looks like the threading leader that labs use to string film through their processors and printers. The second picture looks like a Celco or other brand of burn to film printer. There are a few of them based on Oxberry camera movements. Perhaps a Fury.
Hehe,
that is my personal folder where i store images to display on forums.
the image from alien was from the time i asked about the camera shown on those pictures on this forum a months ago or so.
I should erase that. :D
The Green film is a processing machine leader, it is used on feed the film through the machine. It looks like the top of the racks that hold the film in the chemicals.
The first shot is the top of a processing machine: you are looking at green machine leader that is joined on to the end of actual film, in order to run the real film right through the process and out, while keeping the machine threaded.
I think it's the stop wash tank in the shot - only half a tank is threaded, suggesting a 1/2 minute process time (stop or stop wash) and it's a clear liquid, judging by the puddle on the edge of the tank. Finally the rollers in the previous tank are exposed to air (and light) being above the surface of the liquid, ruling out the developer tank.
Where is the picture from?
The other one looks very much like a Celco Firestorm CRT film recorder.
Yes, it's a processing rack threaded with clear triacetate green processing machine leader. Kodak's subsidiary FPC sells a variety of leaders:
http://www.fpcfilm.com/film-leaders-lab-pr...ne-leaders.html
http://www.fpcfilm.com/film-leaders-editorial-leaders.html
The continuous processing machines used by labs have dozens of racks and many hundreds of rollers, and so are left threaded at all times. When the machine is shut down, it is loaded with leader, usually made of clear base so it doesn't absorb any chemistry while sitting, causing cross-contamination. The machine leader is often a thicker base (e.g., 7-mil polyester) for added stiffness and durability. Machines with sprocket drive require perforated leader. Machines with "soft touch tires" (often used when both 35mm and 16mm are run on the same machine) can use unperforated leader.
Here is the Kodak processing manual, publication H-24:
http://www.kodak.com/US/en/motion/support/...=0.1.4.15&lc=en
Module 2: Equipment and Procedures - discusses the mechanical components of a processing machine.
