scooterbutt Posted April 4, 2005 Share Posted April 4, 2005 what are the best lenses to get for a reflex bolex? wanting a zoom and a wide angle lens. Link to comment Share on other sites More sharing options...
Robert Hughes Posted April 6, 2005 Share Posted April 6, 2005 The Bolex reflex system has a prism in the optical path that requires special lenses to compensate for spherical aberration. Your best bet are the Kern Switar -RX prime lenses for medium and wide angles. For longer lenses (above 50mm) your choice is greater, because the difference between -RX and regular lenses is not as important. Bolex made 3 different quality lens lines, from lowest to greatest: Yvar, Pizar, and Switar. You'd be hard pressed to find a better 16mm C mount lens than a Switar -RX prime for your Bolex. The Switar zoom is well respected, but it's pricey and may be available only in bayonet mount; you'd need the bayonet hard front on your Bolex to use it. Link to comment Share on other sites More sharing options...
Steven Budden Posted July 31, 2005 Share Posted July 31, 2005 Actually, I've been looking for Vario switars in bayo mount and they are much more common and cheaper in c mount. All except for the very newest come in c mount. Steven Link to comment Share on other sites More sharing options...
