SPG64 Posted July 23, 2015 Posted July 23, 2015 If anyone has a set of barn doors to suit In good or working condition. Even if someone could point me in the right direction.. With much thanks SCOTT AUSTRALIA
JD Hartman Posted July 24, 2015 Posted July 24, 2015 I have an entire hamper of barn doors. What diameter?
SPG64 Posted July 24, 2015 Author Posted July 24, 2015 Hi JD, Thanks for the quick reply...I'm just looking at the spec sheet here... The lens diameter is 300mm and saying the accessory diameter is 410mm Hope this is of help, otherwise I can email you the spec sheet.. With much thanks SCOTT
JD Hartman Posted July 25, 2015 Posted July 25, 2015 If the scrim size is 410mm, then unless there is a step in the accessory ears changing the diameter, it would use 16" barn doors. I'll see what I have.
SPG64 Posted July 25, 2015 Author Posted July 25, 2015 Hi JD, Thanks again.. I took a tape across the fresnel front and barn door roller attachment mount.... Yes it would be closest to 16 inch.. If it helps, give me your email address and I will send you a few pics to give a clearer insight , just in case I can describe it to you very well.. Thanks SCOTT
