Mismatching Frames Between Two Cameras
Vitor Galv
 Share
Hey people! Hope you're all well 🙂
I'm editing a 18min video recorded with two cameras (different brands, mirrorless cameras). I syncronized both cameras through the first slate, at the beginning of the videos. After 18min there's a second slate at the end of the recording. The footages are mismatching the "clap" by 2 frames and I've never faced this problem before. There's some audio drifting too.
What can cause this? How can I avoid it and fix it?
The tech is simple, but here it goes:
  • A7s - 29,97fps 1080p XAVC-S 50Mbps;
  • X-T3 - 29,97fps 4k Long GOP 100Mbps;
  • Timeline - 29,97fps 1080p.
Thank you 😄
Link to comment
You have good mirrorless cameras.
However, no matter how good the camera is, mirrorless rarely loses its frames.
Which guy dropped 2 frames? Naturally, this is the camera where the video ends 2 frames first.
If I know exactly where the frame is dropped, I will create an edit point in it and fill one frame (or two frames) with the'morphing cut' feature.
For audio, unless there is a reason to use both audios, I think you should only use the audio track with no problems.
I hope that your problem will be resolved satisfactorily.
Link to comment
Guest
Reply to this topic...
  Only 75 emoji are allowed.
 Share
Forum Sponsors
DMX-iT
FJS International
Film Gears
Cinematography Books and Gear
