Niall Flynn Posted Thursday at 02:27 PM Share Posted Thursday at 02:27 PM (edited) Hi Folks, I got a Desisti 1200/2500 hmi head and ballast, it had a open door fault/bulb disconnect fault showing on the digital read out on the ballast. So on investigation the door open switch wasn't sprung or opening the switch, I looked inside and as expected. The spring had came of the door switch. I repaired this and plugged the lamp head in to the ballast thinking all would be well however the fault still shows up which is definitely been repaired. I wondered do I have to clear the fault in the ballast software to get it back up and running. The ballast and light are in like new condition and ran perfectly before. If anyone could shed any light on this it would be very much appreciated. Link below to video Edited Thursday at 02:38 PM by Niall Flynn Forgot a link of fault Quote Link to comment Share on other sites More sharing options...
Guy Holt Posted Friday at 01:37 PM Share Posted Friday at 01:37 PM 23 hours ago, Niall Flynn said: ... the fault still shows up which is definitely been repaired. I wondered do I have to clear the fault in the ballast software to get it back up and running. How do you know the switch is repaired? The switch may require adjustment after replacing the spring. The only way to confirm the safety switch is functional is to test continuity between the safety loop pins of the head pigtail with the door closed. If you read continuity, the switch is functional. If you don't read continuity, the switch needs adjustment. Guy Holt, Gaffer, ScreenLight & Grip, Lighting rental and sales in Boston Quote Link to comment Share on other sites More sharing options...
