Premium Member Cole Cyccone Posted August 11, 2022 Premium Member Posted August 11, 2022 Zeiss DigiPrime Set optimized for use on S16 (self) dubbed the Master 16s. These lenses were originally made for 3CCD 2/3" sensor HD cameras in the mid 2000s. They were built with the same mechanical construction and optical standards as the Master Primes. These lenses shave been used on movies like Benjamin Button and Cloverfield. Now they are now being offered optimized for S16 film or digital use! Each lens has been collimated and tuned for use with the included highest quality IBE Optics 1.4x Expander / PL converter. This expander/converter expands the original image circle intended for 2/3" sensors for use on a S16 size imager. This high quality converter also converges the light for optimal projection on a single plane as opposed to an image beam splitter on 3CCD cameras where the R G and B light channels were going different directions. The result is a high performance image, highly corrected for chromatic aberration and has no focus breathing. There are a total of 7 lenses to choose from in this listing: 5mm T1.9 - S16 EQUIV - 7mm T2.4 7mm T1.6 - S16 EQUIV - 9.8mm T2.1 10mm T1.6 - S16 EQUIV - 14mm T2.1 14mm T1.6 - S16 EQUIV - 20mm T2.1 28mm T1.6 - S16 EQUIV - 39mm T2.1 40mm T1.6 - S16 EQUIV - 56mm T2.1 70mm T1.6 CF - S16 EQUIV - 98mm T2.1 (minimum focus about 14") All have a 95mm front diameter and matching gear positioning. When using these lenses I suggest you install the IBe Converter directly to your camera and switch lenses from the converter (effectively making your camera b4 mount) for ease of use and only take the converter off the camera when switching to a PL lens. Make sure the PL mount on the adapter and the B4 mount on the lens is all the way finger tight to avoid the lens shifting during shooting from focus gear torque. I have some examples to share privately if you're interested. $10,000 for the set located in Los Angeles Pictures here:https://imgur.com/a/r0q9ZSU 1
Ben Mullen Posted August 12, 2022 Posted August 12, 2022 Hi Cole, Do you have any examples shot on S16 film? Feel free to share those over DM if you do! Ben
Premium Member Cole Cyccone Posted August 12, 2022 Author Premium Member Posted August 12, 2022 Hey Ben, just emailed you ?
Premium Member Cole Cyccone Posted August 13, 2022 Author Premium Member Posted August 13, 2022 Correction on the equivalent T-stop speeds a colleague pointed out. The T1.6 lenses are more like T2.25 with the 1 stop loss of the expander.
Premium Member Cole Cyccone Posted August 18, 2022 Author Premium Member Posted August 18, 2022 Incredibly sharp and high performing big set of s16 lenses for under $10k is hard to find. Snap these up before word gets out.
Premium Member Cole Cyccone Posted August 30, 2022 Author Premium Member Posted August 30, 2022 Bump! Have a few people interested but I have a couple sets available.
Premium Member Cole Cyccone Posted September 23, 2022 Author Premium Member Posted September 23, 2022 Still have a set available and a 1.32x expander from a different company if stop and wide end is more important to you than optical performance!
Premium Member Cole Cyccone Posted November 17, 2022 Author Premium Member Posted November 17, 2022 Still have a set for sale! Equivalents with the 1.32x: 6.6mm T2.5 9mm T2.1 13mm T2.1 18.5mm T2.1 37mm T2.1 53mm T2.1 92mm T2.1
Premium Member Cole Cyccone Posted December 14, 2022 Author Premium Member Posted December 14, 2022 Tests available in LA!
Premium Member Cole Cyccone Posted January 6, 2023 Author Premium Member Posted January 6, 2023 Great set of lenses for anyone shooting S16. Comparable in quality to Ultra 16s and Master Primes.
Premium Member Cole Cyccone Posted February 17, 2023 Author Premium Member Posted February 17, 2023 Sample Footage: Film- https://www.youtube.com/watch?v=pbdsHrTq_SE&t=43s https://www.youtube.com/watch?v=3vfypcu4qK8 https://www.youtube.com/watch?v=UzSpnQmUg0U&t=5s Arri Amira on S16mode: https://www.youtube.com/watch?v=XpHz33gPmMc Test footage:
