David Hessel Posted November 11, 2022 Share Posted November 11, 2022 location: Colorado Vazen 50mm T2.1 1.8x Full-Frame / S35 Anamorphic Lens PL + EF mounts included This lens is currently out of stock at B&H due to high demand. The kit is complete as purchased with all accessories and both mounting options for PL or EF. The optical elements are absolutely mint. The outer body has a couple of small blemishes. Excellent condition all around. Key Features 50mm Anamorphic 1.8x Full-Frame Lens Interchangeable EF and PL Mount T2.1 to T16 Aperture Range Covers up to ALEXA LF 8K Sensor Markings in Both Feet and Inches 95mm Front Diameter, 86mm Filter Thread 3.6' Minimum Focus Distance Shim Set Included Vazen 50mm T2.1 Anamorphic Specs Focal Length 50mm Lens Mount ARRI PL Lens Format Coverage Full Frame Maximum Aperture T2.1 Minimum Aperture T16 Minimum Focus Distance From Unspecified Point in Lens: 3.6' / 1.1 m Gear MOD & Pitch Focus: 0.8 MOD / 32 Pitch Iris: 0.8 MOD / 32 Pitch Front Diameter 95 mm Filter Thread 86 mm Focus Scales Imperial Horizontal Squeeze (Anamorphic) 1.8x Image Stabilization No Length 5.2" / 13.3 cm Weight 3.42 lb / 1.55 kg Add an anamorphic widescreen look to your production with this 50mm T2.1 1.8x Full-Frame Anamorphic Lens from Vazen. The 50mm prime cinema lens provides a 1.8x anamorphic squeeze with slick blue flares and an oval bokeh. It comes with interchangeable PL and EF mounts to fit numerous camera models, and they can be easily changed by the user. It covers full-frame sensor sizes up to the ARRI ALEXA LF open gate 8K frame. The 50mm features a 3.6' minimum focus distance, minimum focus breathing, focus marks in feet and inches, an 95mm front diameter, and an 86mm filter thread. This lens comes with front and rear caps, a PL mount, an EF mount, and a shim set for use on a variety of cameras. Price: $6500 O:B:O Quote Link to comment Share on other sites More sharing options...
