Kevin Ross Posted July 6, 2023 Share Posted July 6, 2023 Excellent working order. This includes a DENZ C0100011 Lens Support for 19mm studio rods, 2x rods, front/rear caps, and a Viking case. Note that the case has degenerated foam and wear, so it is considered a bonus extra to protect the lens in shipping. The lens itself is in very good cosmetic condition with only a few instances of paint wear and touchups if looking closely. There is no external or internal optical problems. The manual rings all function smoothly, consistently, and accurately. This is overall an excellent example of this lens, ready for reliable use. Priced at $18,000. The Canon CN-E 30-300mm T2.95-3.7 L SP PL mount cinema zoom lens is designed for cameras with APS-C or Super 35 equivalent sensor. 10x zoom is designed to cover longer end of focal length spectrum. Featuring advanced optical design with 4K resolution in mind. Relatively fast T2.95 aperture maintained through much of it's zoom range. The 11-blade iris enables a smooth bokeh. Easy-to-read focus, zoom, iris markings - readable from either side of camera. The rings are subtle, smooth, precise, and repeatble with a a constant torque. Focus rotation is about 300 degrees and zoom about 160 degrees. Extremely high quality construction. Anti-reflective coating to reduce ghosting and flare. Large Aspherical elements reduce distortion and give the utmost optical performance. Optics also reduce temperature-induced marking discrepancies and flage-back changes. The internal focus design minimizes breathing. Compatible with standard cinema accessories such as follow focus, matte boxes, etc. This has a 136mm front diameter. Link to comment Share on other sites More sharing options...
