Mike Nagel
Eizo CG275W 27" Pro LCD Monitor - Mint Condition
selling an Eizo CG275W 27" Pro LCD Monitor which has just been professionally calibrated. Monitor is still under general warranty until mid of 2017. Comes with original box. The CG275W has an internal meter that can be used for auto-self-calibration so that the screen always stays color accurate.
Screen is in MINT condition and is located in Los Angeles but can ship within US.
Specs
Technology LCD
Type H-IPS
Backlight type WCG-CCFL
Size 27" / 68 cm (684 mm diagonal)
Native Resolution 2560 x 1440 (16:9 aspect ratio) @ 60Hz
Display Size (H x V) 596.7 x 335.6 mm
Pixel Pitch 0.2331 x 0.2331 mm
Grayscale Tones 1024 tones (a pallete of 65281 tones)
Display Colors 1.07 billion from a palette of 278 trillion (maximum)
Viewing Angles (H / V, typical) 178°, 178°
Brightness (typical) 270 cd/m2
Recommended Brightness for Calibration 120 cd/m2 or less
Contrast Ratio (typical) 850:1
Response Time (typical) 6 ms (Gray-to-gray)
Wide Gamut Coverage (typical) sRGB/Rec709/EBU/SMPTE-C: 100%, Adobe RGB: 97%, DCI: 91%
Input/Output Connectors
Analog None
Digital
1x DVI-D
1x DisplayPort (with HDCP)
1x Mini DisplayPort (with HDCP)
3 user CAL memories that can be used to calibrate the Eizo with a 64^3 3D LUT for perfect color performance.
PM me for pricing.
- Mike
Share this post
Link to post
Guest
Reply to this topic...
  Only 75 emoji are allowed.
  • Paralinx LLC
    FJS International
    Just Cinema Gear
    The Original Slider
    G-Force Grips
    Cinematography Books and Gear
