Joseph Tese
Mobile & Compact DIT Package (Pelican?)
Not really my area of expertise.
Anyone have any good resources for a very portable and compact mobile DIT station? I'm curious also if anyone has developed a a system to fit into a rolling pelican.. Of course, this mainly applies to lower budget smaller shoots. Thanks!
Share this post
Link to post
Years ago, I built a small PC system into a Pelican 1650 case for doing on-set VFX previsualisation and video assist work. It's completely obsolete now, of course, but it was extremely convenient to roll up, throw it on a magliner, and run one cable (two if you want to run it from mains) and go. A similar arrangement could be done now for DITting.
They make panel frames for peli cases so you can fit a panel inside without having to cut holes in the case and spoil the waterproofing. I had the panel cut by a local engineering firm, and they made a folded aluminium chassis that drops inside with the hardware in it for easy access and removal.
The trickiest part of it was finding a monitor that would fit inside the lid, which is a very shallow space. I had to find one where the mains power supply wasn't attached to the back of it. I'm not sure how common such things are now. I stuck it in there with two strips of two-inch sticky velcro and it effectively became a huge laptop with a lot of custom configured internal widgetry.
It survived many intercontinental plane flights and was generally a useful and worthy piece of gear. This conversation makes me want to haul it out and refit it with more modern components.
Share this post
Link to post
Guest
Reply to this topic...
  Only 75 emoji are allowed.
  • Glidecam
    Just Cinema Gear
    FJS International
    G-Force Grips
    Cinematography Books and Gear
