That's about it.  Changing the shutter angle is very limiting and looks odd anyway.  I've had to do it on the iris.  Apparently Deakins had to do it that way on "1917" for some of those shots going from inside to outside or the reverse.
Until the Cinefade is actually available (I was told there were two in the U.S.) or the Panavision LCND, I'll have to keep using the iris.  And I'm not sure how heavy those units are since I'm always doing these long moves on a Steadicam so whatever I use can't be too heavy and it needs to be adjustable by remote.
  • Upvote 1
Link to post
Yes, I agree. Changing shutter is not an option. The Cinefade has been on the market for a year now, so there are certainly more than two units available in LA by itself now.
Total weight of the VariND is 690g. The wireless receiver unit is built into the cforce lens motor, so won't add extra weight. In my experience Steadicam Operators haven't complained about the extra weight on the front when balancing.
Link to post
  • 7 months later...
Could use a Sony fx6 for this shot? That whole camera is less expensive than the cinefade.
Not sure how easy it is to vary the nd in realtime or remotely.
Edited by Mei Lewis
Link to post
Oliver, aren’t you the inventor of the Cinefade VariND? I think you should disclose this when making posts about your product.
Or consider buying advertising space from Tim Tyler and support the forum, since that’s basically what your post is...
Link to post
Guest
Reply to this topic...
  Only 75 emoji are allowed.
