Simon Plunket Posted August 18, 2023 Share Posted August 18, 2023 Hi All, I've tried to see if anyone has posted a similar question but haven't had much luck, apologies if this has already been discussed elsewhere before. I'm looking to try and create the effect a film camera makes when getting to speed, or just after the camera is cut and you have these moments of flicker, like a memory that are overexposed and in fast motion. You can see a few examples in these two projects below. Generally these are used as editing transitions For the Post Malone video timecodes around 0:56 and 1:09, and for the "In My Mind" timecode around 0:13. Would you know if there is a way to force these moments a little longer, are there some cameras that take longer to get to speed? Would hand cranking help to achieve the effect? Does anyone know of any digital examples where someone has been able to create a similar feeling? Thanks in advance! Simon Link to comment Share on other sites More sharing options...
Premium Member Frank Wylie Posted August 18, 2023 Premium Member Share Posted August 18, 2023 Both examples you show appear to have electronic simulations of the effects you are seeking. "Shutter dragging" was pretty popular a couple of decades ago, when the DP would shoot on 16mm on (typically) a Bolex and ease off on the shutter release until the stopping mechanism was partially engaged (horrible rattling sound) which slowed the speed of the camera according to varying amounts of shutter release pressure. It is certainly not good for the camera, but it was done. The effect can be replicated on perfectly good exposed images with a good NLE using dynamic speed reduction curves, ramped exposures, key framing color shifts and so on, but it takes a lot of work and a good working knowledge of the NLE. Link to comment Share on other sites More sharing options...
Simon Plunket Posted August 22, 2023 Author Share Posted August 22, 2023 Hi Frank Sorry not to come back to you sooner but hugely appreciate the response. I hadn't really quite understood what shutter dragging is but makes total sense now. I'll explore this all some further! Thank you Simon Link to comment Share on other sites More sharing options...
Chance Shirley Posted August 24, 2023 Share Posted August 24, 2023 Here’s a $19 AfterEffects plug-in that might help you get the look you’re going for... https://proloststore.com/products/handcrank Link to comment Share on other sites More sharing options...
