Mendes Nabil Posted March 18 Share Posted March 18 Hello all, I'm about to shoot Ektachrome E100 (daylight balanced film) at night on Hasselblad medium format. I will have two tungsten sources, one with a Tokyo blue filter, one without. Two strategies to convert my daylight stock to tungsten : Strategy 1 : 80A filter on the lens. Issues : 1 : I don't know how much light does my 80A filter cuts "exactly", Ektachrome being a slide film, no error is allowed.. 2 : It might introduce some flare or ghost effect 3 :My viewfinder will get dimmer which is an issue at night Advantage: the ambiant tungsten lights will also be corrected Strategy 2 : Gelling my two sources with CTB. Issues : 1 : stacking up a ctb + tokyo blue effect is not a combo i'm sure about 2 : Ambient practical light will not get corrected (They will be minor in the scene) Advantages : No flare issue, and clear viewfinder What would be your strategy? Thank you all, Link to comment Share on other sites More sharing options...
Mark Dunn Posted March 18 Share Posted March 18 The 80A absorbs 2 stops, so you would meter at 25 with the filter on the camera. An undamaged filter shouldn't cause flare and if you use a filter holder you can line up your shot then drop the filter in for exposure. Gelling the lights will likewise cost 2 stops so unless you have a larger wattage lamp you will need to increase your exposure, but you will be metering at 100. Link to comment Share on other sites More sharing options...
