Don H Marks Posted March 23 Share Posted March 23 I have a state of the art full featured still photography darkroom. I currently send all my cine film out for processing and splitting. I wondered why I should not process the film myself. I wonder if anyone else is using the Jobo drum for cine film. Seems simple enough, but I'm not sure how I'd dry the film or split the film. Link to comment Share on other sites More sharing options...
Premium Member Frank Wylie Posted March 24 Premium Member Share Posted March 24 Build a drying wheel. Easiest way is to take to large diameter bicycle rims and bolt marine grade urethane-finished hardwood slats (or 1/2 inch PVC pipe) between the rims. (Think paddle wheel steamer, but with the flat faces toward the rim) Punch a hole in the head of the film, attach it to a slat and wind the film emulsion out around the slatted drum in a spiraling fashion while applying a bit of diluted photoflo to the film with a chamois or soft cloth. When you reach the end, punch another hole and place rubber bands through the hole and clamp them to a slat that provides some tension, but not high tension. Give the wheel a good spin to fling off the water/photoflo and let it dry. Bonus points if you use a rear rim on one side and chain drive a slow ac motor to allow it to rotate slowly as it dries. Congratulations; you're in the Silent Era. As for slitters, many are available on Ebay; they were part of the Lomo tank kit for 35/16 development. 1 Link to comment Share on other sites More sharing options...
