Chaa Ustaoğlu Posted April 25, 2024 Posted April 25, 2024 Hey guys, I have an inkling about the answer to this question but was hoping someone more experienced might be able to remove all uncertainties 🙂 Do the Lightbridge CRLS reflectors change the colour of the light you bounce into them at all? I would think not really since the material on a CRLS reflector doesn't have a particular colour, but just wanted to make sure. Reason I ask is because I want a specific colour filling into the room through a window, and will obtain the necessary Rosco / Lee colour gel to cover my lighting fixture (likely a Nanlux 1200B with FL-35 fresnel) for this. For some set ups outside certain rooms I will be using the CRLS (1m x 1m) reflector, whilst for others I won't. But I would like full consistency in the colour of the light that ultimately makes it into the room from my fixture. I'm wondering if I might need to acquire x2 slightly different coloured gels that will compensate for any difference from bouncing into CRLS, or if it will be such a minuscule difference that it won't matter. Any ideas / suggestions greatly welcomed! Thanks in advance, Chaa.
Nicolas POISSON Posted April 26, 2024 Posted April 26, 2024 (edited) I cannot answer directly. But my understanding is that a reflector beeing neutral or not mainly refers to white light or wide spectrum sources. For a saturated color with limited spectrum, a non neutral reflector would juste change the amount of light reflected, not its spectrum. So if you plan to use colorful gels, I guess it will not be much affected by slight inaccuracy of the reflector. Edited April 26, 2024 by Nicolas POISSON
Premium Member Phil Rhodes Posted April 27, 2024 Premium Member Posted April 27, 2024 The reflective surface on a CRLS panel is aluminium, which has a very flat reflectance. I doubt you'd ever see an issue unless it was horribly contaminated with something.
