I routinely weigh down the scanner lid with an extra hard foam backer to flatten out warped archival material tight on the scanner glass. In the old days we had vacuum frames to flatten things out...perfectly! I've had no trouble with using 16 - 18 pounds on the glass for years. Today I tried 22 pounds on an Epson V600 and it started to break. When I get a chance, I will write up a proper report, but too busy right now scanning! Be careful how much weight you put on your flatbed scanner...they will break!
image.jpeg.478fadadfff91817a7ccdc05e20b8
RPPC - Raw Scan
Oil wells Pacific Coast Highway Huntington Beach
DDTJRAC
This is why you use weights on your flatbed scanner with certain material.
this-is-why-you-put-weight-on-your-scann
In the old days we had vacuum frames. They were for graphic arts. They held the original perfect flat. They were used for process camera work or platemaking. Nowadays you have to use weights to flatten out originals when using a flatbed scanner.
When you get to 22 pounds on an Epson V600...they start to break. That is the moral of the story.
