Up for sale is the rare P. Angenieux 9.5-142mm f/1.8 cinema zoom lens with a PL mount. This professional-grade lens is renowned for its versatility and exceptional image quality, making it a perfect choice for filmmakers who need both wide-angle and telephoto capabilities in a single lens. Perfect for crash zooms:)
Key Features:
  • Focal Range: 9.5mm to 142mm, covering wide-angle to telephoto needs.
  • Aperture: f/1.8, allowing for excellent low-light performance and a beautiful shallow depth of field.
  • Mount: PL
  • Angenieux Build Quality: Known for its durable construction, smooth zoom and focus mechanics, and top-tier optics.
  • Frame Coverage: 15x9.5. (Tiny vignette on s16 cause of distance between back of the lens and sensor)
Condition:
  • The glass is clear and clean, with no scratches, haze, or fungus.
  • All rings (focus, zoom, aperture) work perfectly—smooth with no stiffness or play.
  • Slight cosmetic wear on the body, typical for a professional lens of this age.
  • Regularly maintained, with no issues regarding functionality.
  • 4 weeks later...
On 11/20/2024 at 2:50 PM, Felix Finken said:
Do you have a sample image to see how visible the vignetting is at 9.5mm in S16?
Yes, I do have! I can send you samples if you share your email with me!
Perfect, it's kontakt@felixfinken.de! If you have any other lens tests or footage it would be amazing if you could share that too. Thanks a lot!
  • 3 weeks later...
Is it still available? Can you send me the test footage, including something showing the vignetting? Is it factory PL mount or was it swapped over later?
Thanks, Gregg.
This isn't a cinema zoom, it's an old HD zoom for ENG cameras, it would originally have been B3 or B4 mount and designed to compensate for the beam-splitting prism in those cameras. Can't imagine the image quality wide open is very good used on a modern sensor or film. Pretty sure the aperture ramps from f/1.8 to f/2.6.
Thanks. I was wondering about that. I have been curious about a CANON HD-EC ZOOM LENS HJ21x7.5B-III KLL-SC T2.1, in B4 mount, that comes with an Abakus 132 (about 1.4 extender) B$/PL for S16 format, which corrects the colour fringing. I have seen some test footage with a 1.1 extender and it looked quite sharp, still covering S16.
Just a distraction. I don't need it.
I did some tests, the aperture does not ramps during the zoom.
Every Angenieux 9.5 - 142 I’ve seen has 1:1.8 - 2.6 written on the front barrel, meaning they ramp from f/1.8 to f/2.6.
  • 2 months later...
