Gautam Valluri Posted November 13, 2024 Posted November 13, 2024 Hello all, I will be filming some digitally shot footage off of an LCD TV screen onto 16mm 7207 250D stock. The LCD screen in an old Samsung TV screen with HDMI. I will be screening an 24 fps MOV file on it from a macbook via HDMI. The reason I chose an LCD screen is to avoid strobing. My questions: Do I need to adjust any settings on the screen to avoid strobing or pulsing artefacts? Considering its a European TV screen (HD display), will it play the 24fps MOV file at 25 fps? And in that case do I have to adjust my camera speed to 25 fps? Thanks in advance for your insights,
Premium Member Tyler Purcell Posted November 13, 2024 Premium Member Posted November 13, 2024 Yea shoot it at 25, if it's a modern screen with high refresh, it should be fine. 1
Gautam Valluri Posted November 14, 2024 Author Posted November 14, 2024 16 hours ago, Tyler Purcell said: Yea shoot it at 25, if it's a modern screen with high refresh, it should be fine. Thanks Tyler. I also managed to turn down the back light of the screen to 0 as I was unsure if it was backlit by LED or other lights. I couldn't find any posts on the forum about what sort of an effect LED screens have when filmed on 16mm. Do they strobe like CRTs?
Premium Member Tyler Purcell Posted November 14, 2024 Premium Member Posted November 14, 2024 7 hours ago, Gautam Valluri said: Thanks Tyler. I also managed to turn down the back light of the screen to 0 as I was unsure if it was backlit by LED or other lights. I couldn't find any posts on the forum about what sort of an effect LED screens have when filmed on 16mm. Do they strobe like CRTs? No a good LCD won't strobe. You can test it with your still camera in video mode, set to the same settings as the film camera to double check. 1
