juanobg Posted June 15, 2004 Share Posted June 15, 2004 hi everyone'' B) i will shoot a short film in s16. The next week im going to make some film test's to achieve the look that i want. i was thinking in over expose 1 stop ant then under develope it 1 stop , and vice versa. Also using a coral filter or an ultra contrast filter. The look that i want on my film is very contrasted , with high lights and also deep dark's. the colors of the locations are sky blue , dark pink and green (the army green) . please tell me any suggestion about filters,develope ,or film stock. THANK'S------------ P.D excuse me for my bad english. :blink: Link to comment Share on other sites More sharing options...
Premium Member John Pytlak RIP Posted June 16, 2004 Premium Member Share Posted June 16, 2004 Some overexposure will help increase color saturation on a color negative film. No more than the +1 stop you suggest. Pull-processing will DECREASE contrast and color saturation, so stay with a normal process. Obviously do not use any contrast reducing (diffusion or fog) filter. Use minimal fill to achieve contrasty lighting. Use a polarizing filter to enhance the blue sky. Link to comment Share on other sites More sharing options...
Premium Member David Mullen ASC Posted June 16, 2004 Premium Member Share Posted June 16, 2004 Ultra Con filters and pull-processing both will REDUCE contrast, not increase it. Link to comment Share on other sites More sharing options...
Jarin Blaschke Posted June 16, 2004 Share Posted June 16, 2004 Pushing the negative will give more contrast and grain, as well as a richer image and higher color saturation, as long as you don't underexpose it as well - in other words, shoot it at the speed you normaly would and give it a push process. Highlights might start to block up, though. +1 should be noticeable, and I find that +2 starts to obtain a slight cross-processed look. Link to comment Share on other sites More sharing options...
