Nate Yolles Posted June 22, 2004 Share Posted June 22, 2004 To properly evaluate your work, whether it be still slides or moving pictures, it would seem necessary that your projector be set at the correct level. So, I break out my light meter and my color temp meter and I measure. But what levels am I looking for? I think I remember 16 footlamberts, but I'm not sure. As for color, should the projector be balanced at 3200? Now as I type this, I realize that you can always project a grey card & color chart and compare to the actual charts. I'd still like to know the correct levels. Link to comment Share on other sites More sharing options...
Rob Belics Posted June 22, 2004 Share Posted June 22, 2004 John Pytlak has an article on this on Kodak's website. It's under the Cinematography tab or do a search for his name. Link to comment Share on other sites More sharing options...
Nate Yolles Posted June 22, 2004 Author Share Posted June 22, 2004 http://www.kodak.com/US/en/motion/newslett...d=0.1.4.9&lc=en Link to comment Share on other sites More sharing options...
Premium Member John Pytlak RIP Posted June 22, 2004 Premium Member Share Posted June 22, 2004 Thank you. Standard SMPTE 196M specifies an aim of 16 footlamberts, with an allowed range for theatres of 12 to 22 footlamberts. Remember, the screen is part of the system, so you need to measure light REFLECTED from the screen (footlamberts) with a spot meter, NOT just light incident on the screen (footcandles). Link to comment Share on other sites More sharing options...
Nate Yolles Posted June 23, 2004 Author Share Posted June 23, 2004 Mr. Pytlak has a nice section over at Kodak.com, but I don't think I saw anything about proper color temperature. Link to comment Share on other sites More sharing options...
Premium Member John Pytlak RIP Posted June 24, 2004 Premium Member Share Posted June 24, 2004 Standard SMPTE 196M-2003 assumes the use of a xenon arc projection source: For 35- and 70-mm prints, the light reflected from the screen in theaters shall have a spectral distributionapproximating that of a blackbody at a color temperature of 5400 K + 600 K -- 200 K, the use of short-arc xenon light sources being assumed. For review rooms, where color matching is more critical, projectors shall have a chromaticity match, for the same film format, of x = ± 0.002 and y = ± 0.004. For laboratory use in color timing, projectors shall have a chromaticity match of x = ± 0.001 and y = ± 0.002. Typical chromaticity readings would be D5500: x = 0.332 and y = 0.347. Chromaticity measurement requires a precision chromaticity meter, not a color temperature meter. Link to comment Share on other sites More sharing options...
Ram Shani Posted June 24, 2004 Share Posted June 24, 2004 hi i have the sekonic 508 which has only T STOPS how mach 16 footlambert is in Tstops in let's say 500ASA? ram Link to comment Share on other sites More sharing options...
Premium Member Wendell_Greene Posted June 24, 2004 Premium Member Share Posted June 24, 2004 Set your spotmeter to 100asa @ 1/50. With the projector running point your meter at the center of the screen. You should get a stop of 3.2 (2.8 and 1/3) which is equal to 16 footlamberts. Link to comment Share on other sites More sharing options...
Premium Member John Pytlak RIP Posted June 25, 2004 Premium Member Share Posted June 25, 2004 Remember that a meter that can only read with an accuracy of 1/3 stop will have a hard time measuring the difference between 12 and 16 footlamberts: http://www.kodak.com/US/en/motion/newslett.../june2000.shtml Link to comment Share on other sites More sharing options...
Sam Wells Posted June 25, 2004 Share Posted June 25, 2004 More of an issue might be whether your spot meter can read discontinuous sourcse properly but having said that I've done it with Minolta M & Sekonic 778 and I think I've gotten close enough for an educated eyeball evaluation. More variation screen to screen in typical exhibition venues (for better or worse <_< ) I've always meant to contact Sekonic & ask what the're acceptance window is (dunno if they'd tell me....) -Sam Link to comment Share on other sites More sharing options...
