samuelbrownfield Posted July 17, 2004 Posted July 17, 2004 Does anyone know if the Arri SR3 has a single frame mode, for doing time-lapse shots? The slowest it goes is 5 fps, but I need to do a time-lapse shot ramping into 24 fps from about one frame every 10 seconds. I can't find anything describing a control like this on the sr3, but I'm hoping it exists. Thanks
oscar jimenez Posted July 17, 2004 Posted July 17, 2004 Hi, Im not quite sure about SR 3, but I think SR3 "Advanced" might be capable( check that on the Arri Website ) anyway, you can calculate arithmetically time lapse, the frame rate and the frame burst. If you have a Palm, you can download the software for cinematographers, there is a function for doing that. Cheers
harryprayiv Posted July 18, 2004 Posted July 18, 2004 It is possible with an SR3 as far as I know. I've never had the time just to try it on set and have never had the money to do tests, so don't take my word for it... anyone?
manny Posted July 18, 2004 Posted July 18, 2004 Greetings, You need to change the electronics or add electronics in order to go for single frame on an Arri SR3. Wanted to do this early spring for a commercial, and that is what Arri rental here in Munich said. Regards Manny
