czernichow mathieu Posted January 25, 2007 Share Posted January 25, 2007 I am selling the following LTR 54 package for 6000 $ - Aaton LTR 54 Pl mount, B&W video tap (From visual products), (3)400 ft mags, (3) batteries & Charger Right handgrip, light weight rods, Extension eyepiece, Custom case, Sound Barney, 4x4 matte box - Canon 300mm PL mount 1800 $ - Zeiss T1.3 mixed MKI & II Lens Set PL mount, 80mm fronts: 8000 $ 9.5mm T1.3 MKI, 12mm T1.3 MKI, 16mm T1.3 MKII, 25mm T1.3 MKI, 35mm T1.3 MKI, 50mm T1.3 MKII, 85mm T1.3 MKI Filters : 900 $ 1 série Neutral 1 série 85+ 81ef 1 série Deg soft edge 1 85 pola 138 Sachtler panorama 1400$ If you take a few items negocation is possible. Link to comment Share on other sites More sharing options...
Premium Member Tim Carroll Posted January 25, 2007 Premium Member Share Posted January 25, 2007 - Zeiss T1.3 mixed MKI & II Lens Set PL mount, 80mm fronts: 8000 $ 9.5mm T1.3 MKI, 12mm T1.3 MKI, 16mm T1.3 MKII, 25mm T1.3 MKI, 35mm T1.3 MKI, 50mm T1.3 MKII, 85mm T1.3 MKI Czernichow, A few questions. Where are you located? When were the Zeiss lenses last serviced? Would you consider selling the 12mm T1.3 MKI and the 25mm T1.3 MKII, and if so, how much would you want for those two lenses? Thanks, -Tim Link to comment Share on other sites More sharing options...
