John Adolfi Posted October 2, 2004 Posted October 2, 2004 As promised I said I would post my results on the German chrome stabilizer plate. Here was the set up: I used two cameras 1.) Nikon R-10 2.) Elmo 1012XL-S I set up the camera on a tripod and filmed outdoors. The subject was a close up of a film slate. Each take was 9 seconds long with and without the plate using each of the two cameras. I viewed the films on a white wall where the screne was about 18" across on a Bauer T-610. The projector as far as I know is fuctioning perfectly. As I played the film I turned the framing knob so as to see that frame line we normally do not like to see. My Wife was another witness to this experiment. Here is what we both agreed on. Yes there diffently was a noticable difference in picture stability. After viewing it 3 times my Wife and I both thought there was an easy 50% reduction of line jitter. Was the jitter completely eliminated, no but the improvement was enough to make a believer out of me and as I continue to shoot super-8 this will most defineately be a tool I will consistantly use, enough said.
xoct Posted October 2, 2004 Posted October 2, 2004 Great to hear someone take the plunge and discover a new tool. I appreciate your response. As promised I said I would post my results on the German chrome stabilizer plate. Here was the set up: I used two cameras 1.) Nikon R-10 2.) Elmo 1012XL-S I set up the camera on a tripod and filmed outdoors. The subject was a close up of a film slate. Each take was 9 seconds long with and without the plate using each of the two cameras. I viewed the films on a white wall where the screne was about 18" across on a Bauer T-610. The projector as far as I know is fuctioning perfectly. As I played the film I turned the framing knob so as to see that frame line we normally do not like to see. My Wife was another witness to this experiment. Here is what we both agreed on. Yes there diffently was a noticable difference in picture stability. After viewing it 3 times my Wife and I both thought there was an easy 50% reduction of line jitter. Was the jitter completely eliminated, no but the improvement was enough to make a believer out of me and as I continue to shoot super-8 this will most defineately be a tool I will consistantly use, enough said. <{POST_SNAPBACK}>
andrewbuchanan Posted October 19, 2004 Posted October 19, 2004 I was wondering if anyone had used this tool. Where did you order it from and what did it cost?
Bob Last Posted October 20, 2004 Posted October 20, 2004 You can order it direct from Andec. They take PayPal. I paid $145 on mine. Go to the following website to order: Andec Pressure Plate Just send them an email.
Nate Downes Posted October 20, 2004 Posted October 20, 2004 Any chance for video footage showing this? I need to convince the money handler aka my wife on it.
S8 Booster Posted October 20, 2004 Posted October 20, 2004 You can download samples here: http://www.andecfilm.de/html/demo-bildstand_eng.htm Having tested it quite a bit it is not bulletproof. R
Premium Member Alessandro Machi Posted October 28, 2004 Premium Member Posted October 28, 2004 Are we not supposed to use the pressure plate with a Nikon R-10 because it can damage some internal film gate component on the Nikon R-10?
S8 Booster Posted October 28, 2004 Posted October 28, 2004 Are we not supposed to use the pressure plate with a Nikon R-10 because it can damage some internal film gate component on the Nikon R-10? <{POST_SNAPBACK}> It will not be damaged but there is a huge misfit (stop pin will not operate properly) and it may worsen the result. I modified mine to allow the stop pin to operate properly and the result was amazingly good verified through a double exposure of a test image. R
Matt Pacini Posted October 29, 2004 Posted October 29, 2004 S8 Booster, explain in detail exactly what you mean by "it's not bulletproof. " Also, any chance we can download results of your test? Any pictures of your modification to work with the R-10? Matt Pacini
S8 Booster Posted October 29, 2004 Posted October 29, 2004 (edited) Not bulletproof is that it could not help heavy jitter with the Provia 400F carts tested on more cams. However, bad PRO8 perfs may be one reason for this and it does not fit my Canon 1014 XLS very well. Causes occational jamming due to too tight tolerances. Below you can check out a clip originally not intended for public use. The jumpiness is a projector artifact. Used a non gate adjusted RUSS projector for trash transfer. This is s double exposure with a slightly offset 2. take. For steadiness examination the lines over lines steadiness will be the measure. Severly underexposed but only made for own verification - not posting. Anyway here it is. It is a 5 sec clip repeated 4 times. ftp://ftp.filmshooting.com/upload/video/mov/NR10s.mov 6+mb. The mod made to allow full operation of the stop pin: Not actual plate but this is how it looks. Special steel colour marker is added to the stop pin prior to cart + PP insertion but no film should be in thie gate, The stop pin will "print" where it hits the plate and it is possible to make the mod. Ideally only a narrow slot or 2 holes (there are 2 pins - one for FW and one for RW operation) should/could have been made but I removed this entire section to ensure compability. R Edited October 29, 2004 by S8 Booster
